| For up-to-date information and comments, search the EE Community or start a new topic. |
17-02-2021 12:42 PM
Yesterday I upgraded my contract through the live chat to 160GB there seems to be some issues.
150 shows me that I only have 79.5GB out of 80GB of data.
add-on.ee.co.uk/status shows me that I have 79.5GB out of 80GB of data.
EE App Allowances shows me I have 92.9GB out of 80GB.
and my plan says 5G SIM Plan 24m 160GB £20 Your 5G plan gives you 80GB of data.
I have no extra add-ons other than 100% usage alert.
I contacted EE again today and they had nothing to say other than the other 80GB will be added within 10 days and then quickly ended the chat.
Is this true? The description of my plan seems wrong though. Could there still be an issue? I only have 12 days left before the grace period ends and I'm stuck with the contract.
22-02-2021 01:38 PM
Hi there @JM80
How much data shows if you visit add-on.ee.co.uk when not connected to WiFi?
Thanks 🙂
22-02-2021 01:48 PM
Hi Leanne,
I can only see 80GB showing for my data, nothing in add ons
22-02-2021 01:56 PM
Hi @JM80
Thanks for coming back to me.
In this case, please give us a call on 150 our Mobile Care team will be able to check your plan for you and help you with the data 🙂
Let me know how you get on.
23-02-2021 07:32 AM
Good morning
I have the same problem.
The webpage that you provided above is showing 79GB/80Gb while the app shows 82.3GB/80GB
Any advise please ?
thanks
thanos
23-02-2021 08:05 AM
Morning @Keith2018
Thanks for posting on the community.
If you log into your My EE app and select See my add-ons, do you have any data add-ons showing?
Is the name of your plan correct within your My EE?
Thanks 🙂
23-02-2021 05:48 PM
Hey
yes everything looks okay abs my program name is the correct one
I think you need to fix the issues as these are coming from you guys!!  There are more than one problems about this sim plan!!
thanks
24-02-2021 08:09 AM
Hi @Keith2018
Thanks for checking.
Please give us a call on 150, our Mobile Care team will get your data looked into for you.
Thanks 🙂
13-04-2021 10:46 PM
I have the exact same problem, I shows that I only have 80gb on add-on.ee.co.uk. Could you provide some support?
14-04-2021 07:51 AM
14-04-2021 12:38 PM
No. It shows 78.1 out of 80gb.
