close
Not able to make calls on iphone 12
Lindahd73
I bought an iphone 12 from someone, almost new, I have checked and the phone is unlocked on EE but I'm still not able to make calls
7 REPLIES 7
@Lindahd73  do you have a EE signal showing on the device?
Just checked and there is no EE signal showing on the device
How do you know that phone is unlocked from EE? Did the seller of 2nd-hand goods say so? They don't always know or understand.
Whose SIM have you put in it?
The seller said it was unlocked, I got a new pay as you go EE sim in but still not able to make calls
Can you text AL to 150 & get a sensible answer?
Message failed to send!! Think I'll give them a call tomorrow and see what they say.  Thanks for the advice
@Lindahd73   Where did you get the device from ?  Is the sim in that device working in a different device?  If it does then it’s not the sim but the phone and you need to take this up with the seller.
