close
NO DATA
PhilC7
  • Read more
    Read more
    A new customer, SIM activated yesterday Samsung S8+.  Mobile data not working?
11 REPLIES 11
@PhilC7  Have you changed the APN setting on your device for EE ?
In one word - HUH? What are APN settings for the ill informed?
⁣Get BlueMail for Android ​
Hi @PhilC7
In what way is mobile data not working - can you explain what happens when you try to use it?
Is your device EE-supplied? Or is it SIM-free and being used with a SIM-only plan?
Presumably, but I'll ask, you can make & receive calls ok?
Hi
No problems with phone calls at all.
If I turn off WiFi, the 4G does not pop up - NOTHING happens, phone is offline.
Leanne_T
Hi @PhilC7
Thanks for posting.
Can you try entering the settings in this post if they are currently different, EE APN Settings: Where to find them?
Hi
Have tried around 7 sets of settings, both from Google and from EE sites. None work
Leanne_T
Thanks @PhilC7
Can you try logging into your My EE app and going to Settings, Mobile Data is this turned on?
Thanks 🙂
There is no such field under settings?
Katie_J
Hi @PhilC7.
Please follow these steps:
Menu > Settings > Scroll down to 'Manage your settings' > Use mobile data (please ensure this is enabled).
Katie 🙂
