close
My router playing up
Beckyliburd1998
The last two days my router has suddenly gone from normal, to flashing yellow- WiFi stops.. then to red... Then after a few minutes goes back to normal... Anyone know why this could be happening?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
