close
Mifi saying password is wrong
ecn1
My mifi won't connect to any device, consistently saying the password is incorrect. Can anyone advise pls?
You're talking about the WiFi pwd?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear.
