close
Landline. Not receiving calls
Zed1106
Hi, broadband is working fine but my landline won’t receive calls. Tried from other landlines and mobiles but it’s the same issue, it rings twice for the caller then it sounds as though someone picks up but doesn't say anything. Meanwhile it doesn't ring at all at this end. I can make calls from it no problem which makes me think the phone works. Any ideas what the issue is? Thanks
9 REPLIES 9
Does the phone announce your correct no. when you dial 1470 17070?
Hi, yes it gives me the correct number.
Ring the same no & ask for Ring-Back (Opt 1).
Hi, ok done that and nothing happens when I replace the handset....
Im assuming it should start ringing at that point?
Yes, immediately. Report it to EE as not receiving incoming calls.
Leanne_T
Hi there @Zed1106
If you can follow @XRaySpeX advice and give us a call on 0800 079 8586, we will be able to help you get this looked into 🙂
Let us know how you get on.
Ritz5
My landline not receiving incoming calls. Not ringing either. Any suggestions. Thanks
Ritz5
I am having same problem. Internet good. Mobile good. Outgoing landline calls good. Incoming landline calls not connecting. Landline not ringing at house on friends who have tested. Nothing. ????
James_B
EE Community Manager
Hi @Ritz5,
I'm sorry to hear you're having issues with your landline. Please get in touch with Customer Care so a member of the team can help.
