close
Internet drop out
Shahla32
My Internet drops out for a couple of minutes every night at around 21:30
Its not an issue unless I'm streaming but it is very frustrating.
I'd like ideas as to why.
I've not worried much about it and it's been on going for a couple of years now.
I'm seeking help now because my brother recently had broadband installed at his address and casually mentioned to the technician that mine drops ervry night around the same time and the tech said that is not normal
Would live to hear what people think and/or how to fix it
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
