close
Intermittent internet dropping
asdaf22
So over the past few months I have noticed that throughout the day, whether it be zoom calls, facetime, video games, etc. there seems to be a sudden drop for about 3-10 seconds where no input seemingly comes in. This can happen over 10 times in 30 minutes, and only seems to stop doing it when it gets really late.
There are no signs on the router that anything is wrong, diagnostics on windows 10 suggest nothing, and the internet never actively drops from my pc. I have tried restarting the router.
Any help would be appreciated as it is infuriating.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
