close
Broadband - fine for over a year, now dropping connection multiple times a day
Hi_ImTemmy
Hello,
We joined EE when we moved in back in 2019 and had no connection issues, however in the last few months our internet connection has started dropping out multiple times a day. No wiring in the house has changed.
Where do I start trying to resolve this?
Thanks.
6 REPLIES 6
@Hi_ImTemmy  can you start by calling customer services and reporting it
Leanne_T
Hi @Hi_ImTemmy
Welcome to the community.
If you get in touch with our Broadband Care team, they will happy to get this looked into further for you.
Thanks 🙂
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
Hello @XRaySpeX
The entire BB drops out, affecting all Wifi and wired Ethernet devices.
Here we go:
Router Stats
ry6uROl
Wired Speedtest
https://www.thinkbroadband.com/speedtest/1630761859514561355
Your BB connection seems fine.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
A fault on the line has been detected using the HELP service, and an engineer is due to investigate.
