15-08-2019 09:24 AM
Good morning
Does anyone know how to access
The home hub dashboard with my mobile phone?
Thank you x
15-08-2019 09:35 AM
Thank you x
15-08-2019 12:37 PM
@Timbexl : Do you mean the EE Smart Hub for BB? If so, login to it at http://192.168.1.254 with the admin password on the slider on the back of the router.
15-08-2019 12:38 PM - edited 15-08-2019 12:41 PM
Hi @Timbexl
Welcome to the community. 🙂
Here are the steps to access your hub manager on your mobile:
| Step | Action |
| 1 |
Make sure your EE Smart Hub is connected to your computer |
| 2 |
Open a web browser on your mobile phone |
| 3 |
To access the Home screen, enter 192.168.1.254 or http://eehub into the address bar |
| 4 |
Tap Enter |
03-04-2021 04:55 PM
03-04-2021 07:50 PM
@RogerG2 : Something we can help you with?
23-05-2021 07:27 PM
I'm having trouble with this. When I put in that web address for the smart hub manager into the browser on my desktop PC nothing is happening. It either times out or says it can't connect to it..Any idea why I can't access it?
23-05-2021 07:35 PM
@Bill222 : Is your PC connected to the EE SH in the 1st place? Is your PC getting on the Net?
23-05-2021 07:37 PM
Open the command line interface with Win-R (Windows key and "R" key) and "cmd". Run the "ipconfig" command and check the Default Gateway which should be your router. Type that IP address into a browser.
Your mileage may vary.
