close
Green Bubble
Tilly13
I have a Samsung Z Fold 3 and somehow i have managed to turn on this Green Bubble that comes up when i am in a call.
Can someone help me turn it off
Northerner
Hi @Tilly13
Check under settings, advanced settings.
Or the call settings.
I've tried there, i just don't know what its called to find the right setting. I thought someone on here might know.
Hi @Tilly13 ,
Are the bubbles at the below link the bubbles you are looking for?
When I go into settings and do a search for "bubble", the most promising setting which is shown is "Allow apps to show bubbles" and that is a good candidate for one to turn off. Good luck!
https://www.getdroidtips.com/steps-to-use-bubbles-on-android-10-how-to/
Here is some Android 11 guidance for enabling bubbles, and the reverse of which should help to disable them: https://wccftech.com/how-to/how-to-enable-chat-bubbles-for-all-apps-in-android-11/
If it's showing on s Call then it's probably the Call Recorder Icon that's been set to Record Calls.
