08-04-2021 11:20 AM
I upgraded my 7 year olds iPad in Feb and she cannot use it outside the home. It will only work while connects to a home router. She hasn’t used any data since the upgrade as she has to connect to my hotspot if we are in the car etc. I have tried resetting back to factory settings. Have tried removing the sim and reentering and still not working. I am paying for a brand new device that doesn’t work.
08-04-2021 12:51 PM
Afternoon @Suxyb
Welcome to the community.
Did you get a new SIM card with the upgrade?
If so, are you using the new or old SIM?
Hope to hear back from you soon 🙂
08-04-2021 04:27 PM
08-04-2021 04:29 PM
Thanks @Suxyb
Does the old SIM work in the new iPad?
Do you have signal showing when the new SIM card is in the iPad?
Thanks 🙂
08-04-2021 05:33 PM
08-04-2021 05:36 PM
Sorry for any confusion @Suxyb
That's great thanks, did you register the new SIM card when you received this?
Could you also check something else for me, if you log into your My EE account and go to Menu then Settings do you have Mobile Data turned on?
Thanks.
08-04-2021 07:42 PM
09-04-2021 08:25 AM
Hi @Suxyb.
If you turn off WiFi on the iPad, does it display 4G in the top right corner?
If not, what does it display?
Jon
