30-10-2021 01:21 AM
Hello Community.
I have a Samsung J4+ with Android that I bought from "Three" UK and changed to EE (UK) keeping my previous number but I have no mobile data although I check my plan on "My EE" and it is correct. I tried changing APN, VPN, restarting and still not working.
Can someone help me?!! PLEASE!!!!
THANK YOU!!!!
30-10-2021 09:04 AM
Welcome to the community. 🙂
Have you tried backing up your phone and resetting your phone to factory settings?
30-10-2021 11:54 AM
Hello Chris.
No I did not. Do I need to back up my files an data from my mobile If I do that?
Thank you for your support.
30-10-2021 01:51 PM
Yes, I've included a link with some instructions on my previous reply, @JoseMarillion.
30-10-2021 02:35 PM
Hi @JoseMarillion ,
If you plan to factory reset your device, you may as well give the below a try as it will do no harm given you plan to essentially wipe the device anyway. Good luck!
https://setup-ee.wdsglobal.com/internet
30-10-2021 08:39 PM
Hi Chris
I factory reseted my mobile and still the same problem; no acces to mobile data, not even the icon "4G" appears on the top of the screen. I called to 150 and they "refreshed" my system they said but nothing again. I checked de APN settings from EE to Android divices, nothing. Checked again my mobile, Samsung J4 Plus, and it works with 4G.
Can you tell me what I need to try now please?
Thank you
30-10-2021 08:41 PM
Hi Mike
I factory reseted my mobile and stiil not working the internet mobile data.
Thank you.
31-10-2021 08:15 AM
Thanks for trying that, @JoseMarillion.
I'd recommend speaking to our technical support team again so they can continue looking into this.
Let us know what happens, it would be interesting to know what caused this.
31-10-2021 08:22 AM
@JoseMarillion Can you make/receive calls and texts ?
