Extending 4G EE Wifi router
Options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
20-05-2021 07:32 PM
Hello there,
I would like to extend my 4G Wifi to parts of my house that the signal can't reach, however EE have said that the extenders they offer would not be compatible since they only work with landline connections.
Would anyone be able to advise what my options are? Can I use something like a TP Link Deco? Will it be compatible?
Many thanks for your help.
Options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
20-05-2021 07:35 PM
I'm using a TP Link RE450 with my 4GEE router and it works fine. If your house is on the large size, or you have thick walls don't bother with the cheap extenders - they won't do the job.
