| For up-to-date information and comments, search the EE Community or start a new topic. |
26-12-2021 05:26 PM
Hello, recently my WIFI has been repeatedly disconnecting at the most unsatisfactory times, and only works upon turning off the router and turning it back on. This is a temporary solution, however I'd prefer if it were to stop completely. Is there a solution to this?
26-12-2021 06:57 PM
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
27-12-2021 11:17 PM
