Data add on
davyware
I bought a 500 mb data add on which is supposed to last 7 days oe untill used up but i received a text 10 minutes after buying saying the pack had ended. What can i do to correct this.
Well, half a Gig isn't much data. What were you doing?
I did not even use my data from buying the  add on to the text saying it was used up.
Leanne_T
Hi @davyware
If you would like to get this looked into, please get in touch with our Pay as you go Care team.
You can find details on data usage in our How much data am I using on EE? article.
Thanks 🙂
