on 10-06-2021 01:35 PM
Hi anyone having issues with watsapp on 4G EE?
Solved! Go to Solution.
on 10-06-2021 01:39 PM
Hello @Patrecef
All is good for me. What are the issues you're having? Can you use mobile data for other functions, web browsing etc?
Hello @Patrecef
on 10-06-2021 01:56 PM
no all will be down same time either calls or browsing.
on 10-06-2021 02:03 PM
Does your phone show signal bars? If not, then try restarting your phone and check on the status board under "check network" for any local issues in your area.
on 10-06-2021 02:17 PM
Yes I can see signal bars and if it’s a local issue even than I can’t get in touch with EE customer service team .
10-06-2021 04:31 PM - edited 10-06-2021 04:33 PM
Did you check for or report a problem on the network status checker, @Patrecef?
That way our network team can investigate whether there's a problem locally.
on 13-06-2021 07:08 PM
Network been very very poor I would say substandard. I can’t get in touch with EE . Very poor overall service.
on 14-06-2021 07:38 AM
I have been complaining about very poor or substandard network from EE off late this never happened before and I have had no satisfactory reply so far , after associated with EE for over 6 years it really disappointing .
on 14-06-2021 07:50 AM
Hi @Patrecef.
Have you been able to check our Network Status Checker yet? It will allow you to check for any ongoing work or problems in your area.
How are you trying to contact us?
Jon
on 14-06-2021 06:32 PM
I can’t even check internet speed as the web page only loading all the time and I tried calling on 150 customer service
