close
Changing to smart phone
JimSh
I am contemplating changing fromy old Nokia (not smart) payg.
to a payg smartphone.
Will I be able to transfer my number. ( the Sim cards would not be interchangeable)?
Will I be able to top up my credit using a credit or debit card ( for some reason I was unable to do this on the Nokia)?
Kirigaya_Kazuto
Star Contributor
Star Contributor
Hi.
1. Yes, you can port your number on PAYG - Regarding the SIM question - if you have a combi-SIM at the moment, the smaller SIM size is inside the SIM already so you may not need a new one (it snaps off to make it smaller)
2. Yes, you can top up using a debit card
Enjoy whatever phone you're thinking of getting, Just because I'm curious, what are you looking at getting?
I don't use a 'phone much so was thinking of getting an alcatel 1 and see how I get on.
To save the SIM going into hibernation due to lack of use, just remember within every 179 days (~ 6 months) to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from any Pack or Add-on you might have.
