close
5G contract using 4g device
Ykcool
I’m currently n payg sim only, I’ve noticed a deal of £20 for 120gb on 5G, in the small print it says if you use a 4g device you will only get 4g. I believe the above deal is quite good and also better than a 4g plan, so is it right that I can use the 5G pay monthly contract for my 4g device? Thanks
7 REPLIES 7
Kirigaya_Kazuto
Star Contributor
Star Contributor
Hi, Yes. you can use a 5G contract SIM in a 4G only device. I have done so.
Even with my current iPhone 12 Pro Max when I'm not in a 5G area, it will drop down to 4G
Is it a same size SIM card?
Yes, it is. it'll be a nano sim
Hi @Ykcool
For clarity's sake, are you on PAYG or pay-monthly? The two are entirely different - a SIM-only plan is still a pay-monthly plan.
5G is not currently available to PAYG users.
Any pay-monthly SIM (regardless of plan) will work in a 4G phone and access the 4G network.
"For clarity's sake, are you on PAYG or pay-monthly?"
He's wanting to move from PAYG to Pay-monthly by the sounds of it
For clarity’s sake........I’m on payg at the moment, but looking to go on sim only, but pay monthly, not payg
That's useful, thankyou.
In which case all of EE's pay-monthly plans will allow access to the 2G, 3G & 4G networks.
If you have a 5G-plan and a 5G device, then you will be able to use the 5G network where it's available. You'll continue to use the 4G network if you're either not using a 5G device or not in a 5G area.
