on 08-12-2020 11:01 AM
Hi everybody
I have a yearly contract and paid monthly for a certain amount of calls,emails etc. Have a nokia 3. Problem is the battery is dying and I will be in Spain for the next few months. Can I just buy a phone in an electrical shop and transfer the sim over. My friend says you cannot transfer over to a Spanish phone.
Thank you
Brendan
Solved! Go to Solution.
on 08-12-2020 11:13 AM
Hi @Brendan2 and welcome to the EE community
Providing the phone you buy in Spain is unlocked, and will accept your EE SIM, I don't see any reason it shouldn't work on the Spanish networks.
I would recommend you try your SIM in whatever phone you want to use, before you purchase it. And also make sure you purchase from a reputable seller that isn't likely to report the phone lost or stolen at any future point.
