| For up-to-date information and comments, search the EE Community or start a new topic. |
13-12-2021 03:27 PM
Hi All,
First post and it is a problem I'm afraid. I have just changed to EE from O2 and the BT Email App now fails to work - any ideas?
I can still get webmail going through the mob internet / MyBT, but the App fails to recognise my Login and Password - both are still recognised by my old (now sim card-less) mob and on my desktop; it therefore seems to be a prob with the BT/EE combination.
Help please...
Rgds
golf.lima
13-12-2021 03:29 PM
What have you put as the Incoming Server settings (all of them) in your Mail app, obscuring your name?
13-12-2021 03:42 PM
Thanks for the quick response - because it's an App, I don't believe there are any settings to be entered or changed. You download the App (from 'Playstore') enter your email address and your password and the App does the rest....
As I said - the App runs fine on O2 but not on EE.
Rgds
golf.lima
13-12-2021 03:52 PM
... should have said - this is my first day 'live' on EE do things take a while to set up etc...?
Rgds
golf.lima
13-12-2021 04:11 PM
Hi @golflima ,
Do you see an error message which you can check against those shown at the below URL?
https://www.bt.com/help/email/bt-email--help-in-understanding-errors
13-12-2021 04:45 PM
...thanks all for suggestions gives me faith in the EE forums.
Using the BT email App and then deleting that and using the 'Blue Mail' App - BOTH return a email address / password not recognised - the Blue Mail helps with an error code of (3010) 'server returned No, invalid user name or password'...
I really don't want to go along the route of changing passwords multiple times but is this my only resort...?
golf.lima
13-12-2021 04:52 PM - edited 13-12-2021 04:54 PM
Just check that the email addy/pwd you are using with Mail apps are the same as when using BT Webmail.
What are the settings used in the 'Blue Mail' App?
13-12-2021 05:02 PM
Hi @golflima ,
As a sanity check, please may I check whether you've already followed the below? Perhaps that information is now out of date?
https://www.bt.com/help/email/manage-email-account/manual-settings/setting-up-your-email
13-12-2021 10:18 PM
Assuming this app uses standard IMAP or POP3 (the "universal" standard for receiving email), the connection you're using shouldn't matter for downloading email.
I would certainly expect outgoing emails to have issues when you change the method by which you connect to the internet - in this case, O2 mobile > EE mobile. Unless you specifically use a password in your outgoing email config.
The latter is in the nature of "SMTP" which is how emails are sent.
14-12-2021 07:33 PM
....SUCCESS - thank-you one and all.
Despite my email address & password combination working fine on every other device I own, I bit the bullet and changed my 'BT Mail' password using Yahoo on my mobile - AND IT WORKED....!!!!
It did mean however that I then had to change the password on all my other devices - but hey-ho - at least I can now get emails on my new mob.
I have also downloaded and am using 'Blue Mail' as it seems to be a far more user-friendly App to this dinosaur 🙄
Thanks to all once again,
Rgds
golf.lima
