close
Car data sim card
Katie1984
Hi all
I hope someone can help. Im a bit confused. I am an EE customer, and my Urus takes a sim card, which means my passengers will have wifi. It says i have to give the cars imei to EE? Is that right? Can't i just put a normal sim card in it?
10 REPLIES 10
@Katie1984 Is there a place to slot a SIM card in ?
Yes. And i have put a sim card in. However, the advice and set up on youtube says i have to provide the cars imei number to EE? And get a car data sim? Im so confused lol....
Can't think why. You may put any SIM in any device that it fits.
If you've got s SIM Slot then as you correctly say just put the SIM in there, no need to pass other info to EE.
One thing that you may or may not need to do is set up the APN (Access Point Name) for the correct EE Settings but most units or phones now are Self Configurable.
Try it and see.
@Katie1984  Try THIS YouTube clip. EE don’t need a IMEI number for this to work.
Again don't need to do any of that, just the SIM in and may be check APN, but as said shouldn't need to it's should all be Plug and Play these days.
Time stamp 0.35 sec... he says it as well.... i have to go to my provider with the car imei number and ask for a car data sim
..... im just wondering.... must be a reason for it..... seems too easy to do what ive done lol....must be a catch!
It's a USA Video, just put your SIM in.
Thanks all.... Will see how it goes....but so far so good just putting the sim in!
