06-04-2021 10:53 AM
My android phone has suddenly stopped sending or receiving texts. I can still receive incoming calls, but not incoming texts and I can't send texts Either. It was working fine and I was texting back and forth with someone and then suddenly my texts would not send. I tried to check my balance but texts to 150 will not go through either. I then tried to top up online and that did not work either. I tried to call 150 and it said I did not have enough credit to make the call (I am currently outside of the UK) I think September 2020 was the last time I topped up, but I'm not certain. My SIM is an old T-Mobile one if that makes a difference.
06-04-2021 12:40 PM
Hi @Sarah9090
Welcome to the community.
Did you receive any messages from us recently about your phone going into hibernation?
Do your calls go through OK?
06-04-2021 02:32 PM - edited 06-04-2021 02:34 PM
IrI haven't received any texts about hibernation and I can still receive calls fine, but can't make them
06-04-2021 02:35 PM
Could you try connecting manually to a different network provider please, @Sarah9090?
06-04-2021 03:16 PM
There are only 3 networks available to me in the country I am currently in, and orange (which I was already on) seems to be the only one I can connect to. The other two say 'unable to connect. Try again later' @Christopher_G
06-04-2021 03:28 PM
OK thanks, @Sarah9090
It may be worth getting in contact with our Mobile Care team. You can find out contact information, including an international number, on the get in touch help page.
