close
Buying Data for PAYG MBB in tablet or router
j0hnh4rv3y
I have a tablet and a router, both with 4GEE PAYG MBB Data Sims.
when I try to buy more Data in MyEE App I am only offered to purchase Data Add-Ons which last 30 days or 90 days. I don't see any way of buying a monthly recurring PAYG Pack, unlike on my 4GEE PAYG phone.
My query is:-
Is it possible to buy PAYG Packs on 4GEE MBB Data Sims?
j0hn
Christopher_G
Hi @j0hnh
Any of these pay as you go packs and SIMs can be used in compatible tablets and mobile broadband devices.
Have you thought of a pay monthly SIM only contract? There's some great 30 day and 24 month options on there.
6 REPLIES 6
j0hnh4rv3y
In the iOS MyEE App there appears to be an error on the
Pack15, Get Add-Ons,
“PAYG”
“Add-Ons”
“UK & UE Data”
“10GB Add-On (30 day) £13”
Lower down it says
“500MB for 7 days”
(contradiction in both quantity and period)
Similarly in the
“2GB Add-On (7 day) £8”
“5GB Add-On (7 day) £10”
The footnote again says
“500MB for 7 days”
(contradiction in the quantity)
j0hn
@j0hnh4rv3y   Sounds like they are pre-loaded with data and are not PAYG sims.
with PAYG you can not purchase an add on that lasts over 30 days.  What you have is a sim that has data already on it and that data will last a period of time until used up.
j0hnh
Thanks for your reply Chris
You are correct, they were purchased as pre loaded data sims a year or so ago, when I still had my phone on T-MOBILE 3G PAYG. But since upgrading my phone to EE 4GEE PAYG I've found that the monthly Packs are convenient.
I was wondering if it was possible to do similar with my tablet and router but t seems I'll have to consider using up existing data add-on(s) and then get new EE PAYG SIM with monthly PACK.
Is it ok to use this type of SIM? I thought they were for use in mobile phones only?
Christopher_G
Hi @j0hnh
j0hnh4rv3y
Plenty to think about.
j0hn
EE PAYG Data SIMs don't have recurring packs, just data that lasts either 30 or 90 days & can be renewed manually as add-ons. For packs you would need to use an EE PAYG phone SIM instead which you may use in an MBB router if you like.
