Broadband
Wanqun
My home's broadband is always unstable. It's always disconnected. It's like this every day. I'm very unhappy
@Wanqun : Welcome to EE's Home Broadband Forum.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
