close
Broadband Speed
BobTowns
You advertise Fibre Broadband for my address with a minimum guaranteed speed of
20 MB/s
My speed this afternoon is 14.85 MB/s.  False advertising or can my speed be improved?
12 REPLIES 12
Mustrum
Not fake advertising, but faults do occur.
How is your phone line, is it quiet when you dial 17070 option 2?
To help you further, these are the questions asked by @XRaySpeX @
Have you just joined EE BB or were you already with EE BB? How long has this been happening?
What lights are showing on the router?
What does it say after you log into the router:
  • For a BrightBox: in the Internet section on the initial Status page or
  • For a Smart Hub: on the Advanced Settings / Broadband / Internet page?
Obscure your names & any numbers in the BB Username but post the 1st 2 parts of the IP addy. This will tell us at which stage EE have got to.
Is this for ADSL BB or Fibre? Which router, BrightBox 1 or 2 or Smart Hub?
Does the landline phone work? Do you get a dial tone? Does it announce your correct no. when you dial 1470 17070?
It's sometimes possible to improve the speeds you are seeing.
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
@Mustrum :
Please be aware that the diagnostics I ask for there are for when there is no connection on the line, not when it is a speed issue.
You are getting 22.4 Meg. It is above EE's Guaranteed Min. Speed that you quote. However I think there is some leeway to improve it.
Now do the speedtest I requested as I think you are gauging your speed from speedtests but that's not how EE & the rest of the industry measure, advertise & quote BB speeds.
Your cab. is not scheduled for FTTP.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
