close
Activate Voicemial
CSaunders01
Hi
I have an iPhone10 and am trying to get my voicemail to work on it.  I have set up a message etc as per the instructions on the ee voicemail guide but the voicemail wont kick in when called.  I have tried one of the quick fixes seen on the forum by texting VM OFF to 150 and had a response saying that my conditional diverts has been cancelled and then sent another text to 150 VM ON.  All I keep getting back is a message saying that they are having some problems completing my request and to try again later.
Does anyone have any suggestions please?  This is my work mobile so I need the voicemail to work!
Connie
Hi @CSaunders01
If the VM OFF worked, but the VM ON is consistently failing, I would ordinarily suggest calling EE C/S to get your account checked for any obvious issues.
Having said that, if this is a work-phone you may have limited access to C/S to do this - it may be worth checking that you can call your voicemail ok. Either by calling 222 or speed-dial 1.
You can try calling EE C/S yourself, but they may require you to go via your work's telecoms contact.
Hi @CSaunders01
Hi Bristolian
Thanks for your response.  I can access the voicemail service without a problem.  I had a feeling it might be a C/S solution.  I will give them a call.
CSaunders01
Jon_K
Former EE Employee
Hi @CSaunders01.
Could you try restarting your phone after you've sent the texts?
If this doesn't help, let us know how you get on after calling 🙂
Jon
Hi Jon_K
Thanks for your advice, I did try that but no joy.
Have now spoke to EE Tech Support and they have got it working again, but can't tell me what the issue was with it!
CSaunders01
Katie_J
Thanks for coming back and letting us know @CSaunders01
Have a great evening,
Katie 🙂
