close
Accidentally locked pay and go sim
steveadams82
  • Hi all, just received 2 pay and go Sims for my lads but one of them has managed to lock the sim and it's asking for puk code. It's only an old Nokia 2760 flip phone. How do I get the puk code as I can't get into the phone now(with sim in) or would it just be easier to order a new sim. Cheers
You'll find the PUK, to unblock your SIM after too many incorrect PIN attempts, in your online MyEE under Account Settings / Unlock your SIM.
Thank you,
found the puk code and now it says sim rejected.............
is that the sim now screwed?
Cheers
Is the phone either unlocked or locked to EE?
If the PUK was entered incorrectly 10 times, then you will now need a replacement SIM - that one is now permanently blocked.
If that isn't the case, then as already suggested - the phone maybe locked to another network's SIM. Has the phone been used with an EE SIM before, or which network was it on originally?
Can you try the phone with another EE SIM?
