4GEE Wifi connection
gergototh
From one day to another I am unable to connect to my 4GEE wifi (EE70)
All the lights are on, not flashing. Tried to restart it several times but same issue. Battery out and back.
Cannot connect to it by using the IP address.
9 REPLIES 9
Can you connect to it by WiFi?
No, nothing at all
What happens when you try to connect to it by WiFi?
As I said, nothing. Non of the phones can see the wifi at all.
Nothing
James_B
EE Community Manager
Hi @gergototh,
Does the WiFi network reappear if your restart the router?
Have you tried 'forgetting' the network on your phones and reconnecting?
I am sorry, but I did write it about restarting doesn't help and no phones can see it. Even phones which have never been connected to it.
All lights are on, now about 24 hours without charging.
James_B
Hi @gergototh,
Have you tried a hard reset? (Press and hold the reset button for five seconds with a paperclip)
Of course.
Tried everything, everything
James_B
Hi @gergototh,
In that case, please get in touch with Customer Care so our Tech Gurus can run through some diagnostics and arrange a replacement if necessary.
