11-01-2021 01:50 PM
HI there,
Sorry if this is obvious. Could someone advise me the difference between the home router and the home router 2. There is a £50 price difference and all I can see is 4 ethernet ports as opposed to 2.
Will
11-01-2021 06:56 PM
Hi @wstaylor,
The 4GEE Home Router 2 also supports the connection of up to 64 devices over WiFi, as opposed to 32 on the older device.
Hope this helps.
02-03-2021 04:25 PM
Are there any other advantages?
02-03-2021 05:11 PM
Hi @b88ee
You can find more details on the 4GEE Home Router 2 on the EE Shop 🙂
Thanks.
02-03-2021 05:57 PM
The Home Router 2 will have a slightly better LTE Cat Specs so will be bit more future proof on Advanced 4G LTE Network Speeds, Check your EE Network Coverage Map for more info.
Is there a reason that your not looking at 5G Routers and Plans.
