| For up-to-date information and comments, search the EE Community or start a new topic. |
10-05-2021 02:33 PM
I've been using the 4GEE home router (model HH70VB) now for some time and I'm pleased with the performance. The LAN output on the router is connected (hard-wired) to an unmanaged switch. I now want to connect (hard-wired) some means of transmitting the wifi signal into the garden on one side of the house. I was told that this would require an Access Point to convert from the wired network to the wifi signal, so I've acquired a TP Link Wireless AP/Client Router (model TL-WR843ND).
Firstly, I'm not sure that the TP-Link unit is is the corect device - the person in our local computer shop seemed sure about it. Looking at the TP-link website it looks like this device is more suited to convertin the wifi signal to a hard-wired LAN - the opposite of my intention. Am I reading things wrongly?
Secondly, assuming that the TP-Link unit is the correct one, how do I configure the system to accept the wired TP-Link device? Connecting to the network I can't see the TP-link unit. I can access the advanced settings in my 4GEE router.
Thanks for any help.
11-05-2021 08:41 AM
Thank you for your help. I'll try again later today and report back.
11-05-2021 01:52 PM
Success! The hardest part seemed to be connecting to the TP-Link box. I managed this by disconnecting the unit from my network, doing a factory reset (it was used item), and then connecting to one of the device's LAN ports with my laptop. After that it was just a case of following the steps in the video and connecting the TP-link back into the house LAN hardwired cabling.
By positioning the router next to a downstairs window we now have wifi well down our garden - just in time for streaming my daughter's wedding ceremony in the garden to my son in New Zealand.
Thanks again for all the help.
11-05-2021 02:08 PM - edited 11-05-2021 02:11 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Just as I said!
Just for my info:
11-05-2021 03:45 PM
Once I had connected the TP-link directly to a computer using an ethernet cable the instructions in the video worked perfectly.
Manually change IP address (in my case to 192.168.1.2)
Reboot
Manually turn off DHCP
Reboot
All now tickety boo!
11-05-2021 06:52 PM
Why didn't you use the AP Operation Mode (Part 1 of Video)? That's what it's designed for.
11-05-2021 09:12 PM
At 0:55 in the video I reckoned that the config shown there matched what I was trying to achieve. I'm pretty ignorant of system configurations and associated jargon, so when I saw something that matched what I wanted to achieve I went for that. And it worked, so I'm a happy bunny.
