close
4G Router
gca
I am using a 4GEE Router (model B625-261). When not in use is it OK to power off? I know with a land line router it is best to keep the power on for connectivity to the exchange, so I am thinking that this will not apply to a 4G router. Also it is my bit to conserving electricity, although it is only a small amount, but it all helps.
Yes, you may power it off whenever you like.
