on 16-10-2020 08:50 AM
Left BT due to slow speeds.
Joined EE with EE Router. 50GB per month.
More often than not i have to set up a Mobile Hotspot on my phone - Again EE - and this connection enables me to work from home. Thus paying twice.
I need the router to do what it is supposed to. External antenna fitted and I am 600m from the mast in the countryside and so clear path to it.
EE try to help but say they can't do anything. I would like to exit the contract if it can not be improved upon.
Any ideas/advice gratefully received.
on 16-10-2020 08:54 AM
Hi @LordToft
When you say BT, do you mean BT Mobile (the EE "MVNO") or a BT (Openreach)-based fixed line provider?
What EE router do you have?
What speeds are you getting, and do these vary depending on time of day for example?
