Can I down load a voicemail from a blocked caller?
Jest
I have received a voicemail from a person I blocked. As they are blocked it doesn’t show in my voicemails on my iPhone, Phone screen. I just got a text to call 222.
Can I download this another way as need to keep it, rather then trying to record on another device as it’s played?
@Jest   You can do on device screen recording and this will automatically record the sound when you call the voicemail
  1. Go to Settings > Control Center, then tap. next to Screen Recording.
  2. Open Control Center, tap. , then wait for the 3-second countdown.
  3. start the voicemail
  4. To stop recording, open Control Center, tap. or the red status bar at the top of the screen, then tap Stop.
No - you'll need to record this onto another device as you play the voicemail. I've no idea if iOS allows recording of audio directly from a call to the voice recording app, but that might be another option.
Thank you, wish I’d know this  a couple years ago!
Also thanks for step by step!
