No caller ID showing when SIM is in slot 2 help please
RadioheadFan
OK so I was on Plusnet for 3 years and moved to EE on their advice about a year ago. EE calls would often not work or the person calling me would go straight to voicemail. I noticed how 4G band would drop to E and I would require a network reset done by EE and things would temporarily work again. This has been done multiple times in the last year.
I called up tech support level two recently and they advised settings called IMS was not setup right which is required for 4G communication networking he advised me to factory reset the phone which I did and after this 4G calls were allowed to go through, confirmed several days later by the same tech guy. The phone stopped working again just days later and after doing some reading, I discover that the SIM card slot itself may have issues and so I tried using SIM slot 2. I now get success in that my phone calls work fine, except for the fact caller ID is not showing on incoming calls. It's been called by two mobiles and a landline multiple times and it does not show who is calling, despite that number being in the contacts list. When I called the phone with the SIM in slot 1 caller ID comes through but I cannot take the call as it drops out again from 4G to E. The handset is Xperia 10 III with Android 13, all updates applied.I have used the phone with my sisters 3G SIM in and it worked fine.
I find the tech support absolutely useless with EE, at least two level two techs have not responded to my emails and every time I speak to someone I have to go over everything again. I was told recentlty to replace the SIM and it temporarily worked again, why wasn't I told to try this last year? Another issue, the level two tech guy who noticed 4G coms wasn't installed their end, why didn't the tech guy I spoke to two months ago check this? I explained  the  whole 4G drops to E a year ago so why didn't they look at that in better detail back then?
Thanks in advance.
6 REPLIES 6
To clarify.. with your SIM in slot-1, you go through a cycle of "all fine" > calls stop working > factory reset phone > "all fine" ?
SIM in slot-2.. caller ID missing?
This sounds very much like a device fault on the face of it. What's the result of testing your SIM in a known working phone?
Point 1. All fine temporarily.
Point 2.
Testing my SIM in a known working phone did not help, thus I got a new SIM card recently. I don't think testing it in a known working phone is a solution given the phone works on SIM 2, it's the lack of caller ID that is the issue. I looked through loads of settings but nothing about contacts or caller ID baring is displayed..
Testing in a known working phone will be a good test of whether the device is causing these issues - either in full or in part.
It will also prove the SIM & network setup.
Yes I know, any other ideas? If I use the complaints procedure does that get someone to actually work on the issue properly?
Much depends what you mean by "work on the issue properly". Testing the SIM in a known working phone is as much a part of investigating as any other step.
Are you using the same phone on EE, as you were on PlusNet? And when did this problem start?
Well, avoiding the third paragraph of my original post. Just to reiterate, the phone's SIM was tested in two other phones, one of which an EE shop assistant's.
I am using the same phone as I was on Plusnet, I had updated my phone about 2 months prior to joining EE and did not notice this problem. The problem started about a month after I joined EE.
