on 06-05-2025 11:44 PM
My A20e is locked to so and I can't use my 02 contract sim need to get it unlocked to all networks how do I do it and what's the cost
Solved! Go to Solution.
on 06-05-2025 11:52 PM
@Rastis53 : You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
