Bug Report: Android 17 / ColorOS 17 falsely reports EE UK physical SIMs as "SIM1
davecres1
Affected Devices: OPPO Find X10 Pro Max (CPH2913) & Google Pixel 11 Pro XL
OS Version: Android 17 / ColorOS 17
Network: EE UK (MCC 234 / MNC 30)
Summary of the Issue:
When inserting a valid, active EE UK physical Nano-SIM card into SIM Slot 1, Android's SIM Manager / Carrier Services immediately displays the message "SIM1 has been converted to an eSIM" and disables the physical SIM slot. The physical SIM has not been converted to an eSIM.
Steps Taken to Isolate the Bug:
  1. Tested multiple EE SIMs: Tested both the original EE SIM and brand-new EE replacement physical SIMs—every EE physical SIM triggers the exact same error.
  2. Tested on non-Google SIM stacks: Inserted the exact same EE physical SIM cards into an iPhone and an Honor Magic 8 Pro. Both devices register on EE and work normally, confirming the physical SIMs are active and unconverted.
  3. Tested another UK network in the same slot: Inserted a Three UK physical SIM into SIM Slot 1 on the OPPO Find X10 Pro Max—it registers immediately with zero error messages, confirming the phone's SIM reader hardware is working properly.
  4. Cleared local caches & updated firmware: Reset mobile network settings, cleared Carrier Services / telephony caches, and installed the latest device updates, but the issue persists.
Technical Conclusion for EE Network Engineering:
Because this occurs across different Android 17 devices that rely on Google's native SIM Manager / Carrier Services framework (Pixel 11 Pro XL and OPPO Find X10 Pro Max)—and only triggers when EE UK (234-30) physical SIMs are inserted—there appears to be a mismatch or erroneous eSIM entitlement flag inside EE's Android 17 carrier configuration bundle.Please can EE's technical/carrier-config team investigate and push an updated carrier configuration bundle to Google Play Services / Carrier Services so EE physical SIMs are no longer locked out on Android 17 devices?
0 REPLIES 0
