08-10-2026 06:07 AM
Hi. Can anyone help me please. I cannot connect to National Lottery website or app. I have parental controls off. i've turned VPN off. Cleared cache and data from app. App initially said 'It could be you' but then it came up with same error msg of 'Something went wrong. Please check your connections. It's driving me insane as it worked perfectly fine on this phone previously. Thank you.
08-10-2026 10:55 AM
Hi @NikNak1001
