14-09-2021 02:05 PM - edited 20-09-2021 01:07 PM
iCloud Private Relay
iCloud Private Relay is a new service being offered as part of an iCloud+ subscription that will allow any customer with a device on iOS 15, iPadOS 15 or macOS Monterey to connect and browse the web more privately.
It works by ensuring traffic leaving your device is encrypted so that no one can intercept and read it, including mobile and wi-fi networks and Apple.
To use iCloud Private relay, you must be on iOS 15 or newer and have an iCloud+ subscription.
To turn it on you can either go to:
OR
There are also specific controls for Safari:
To turn it off, you can either go to:
OR:
To turn off specific controls for Safari, go to:
iCloud Private Relay will protect Safari traffic from being visible to anyone. This means we can't prevent access to Strict or Moderate content for customers with these settings on Content Lock.
Some or all of the data used whilst streaming content on devices using iOS 15 with iCloud Private Relay switched on will not be zero-rated as we cannot link your EE customer ID to all of your activity.
No. This will work in the same way for Mobile Network and Wi-Fi connections.
No, you will still be able to purchase additional data as normal on My EE. However, if you are purchasing additional data from add-on.ee.co.uk you will need to turn off iCloud Private Relay first and then reload the page. If you are completely out of your data allowance, you can continue to access add-on.ee.co.uk without switching off iCloud Private Relay.
25-09-2021 09:38 AM
It is important for people to know that although it isn't the same, this is like using a VPN, you use iCloud Private Relay and it hides what you are doing from the world.
If you have any questions then feel free to ask. I am always happy to help!
26-09-2021 04:52 PM
I wish I could set up a rule to turn it off at home as I have an Adguard Home appliance running which blocks all ads on everything on my network. It doesn’t work with my phone or iPad when private relay is turned on though.
29-09-2021 08:54 AM
I think that would be a great feature to have.
Maybe if a few of us leave comments with the apple icloud feedback form, someone will do something about it.
https://www.apple.com/feedback/icloud.html
29-09-2021 09:36 AM
Done.
08-10-2021 11:47 AM
You can disable iCloud Private Relay on a specific WiFi network in Settings. I do this for my home network.
Note that AdGuard and Private Relay aren't the same thing, though.
08-10-2021 11:58 AM
A VPN certainly doesn't hide what you are doing from the world. At best, it will hide what you are doing from your own ISP but it is not an anonymising tool and won't protect you from profiling, protect your passwords or, if using a mobile phone, hide your GPS location.
08-10-2021 02:21 PM
@Umiamz As I said previously, it is LIKE using a VPN, but it is not the same.
08-10-2021 02:23 PM
I didn't see that feature in ios 15.0.0, did it get added in 15.0.1?
08-10-2021 02:33 PM
So it’s not like using a VPN then.
