02-09-2024 06:45 PM
Is just me but every time I turn on my pro box I get code Yvm102 or 105
01-06-2025 09:01 AM
Will do
Nigel
04-08-2025 11:57 AM
Yvm102 and Yvm105 is an issue with the EE boxes, a bug that is never fixed and requires a full reboot of the mini box to get it working again. Usually it happens when you turn on the box after not using it for a while, but sometimes it happens whilst watching. Having to reboot is not a good enough response if that is what EE tells you, having to go through full reboot routines every time you want to watch a TV is not something to live with.
The power or speed of your WiFi seems irrelevant from my experience. I've had it happen to a mini box 3.5 meters direct line of sight (opposite sides of a kitchen) from an EE Smart Extender with over 100mb speeds.
The only fix for these kind of issues solved by reboot seems to be for EE to send you either a powerline adaptor (if that works on your electric circuits) or another smart extender - and using LAN instead of WiFi. Even over LAN this error may still occur occasionally, but it is far less often.
My personal opinion is that EE should be shipping Powerline adaptors by default for this problem because it is so common until it is fixed.
26-08-2025 09:53 AM
Not just you mine does every other day
20-09-2025 05:16 AM
Seems like they still haven't found a fix 1 year later.
20-09-2025 11:29 AM
Thought I'd update as it has been months since EE gave I used powerline and extenders to have all EE TV boxes using lan.
The issues have decreased in regularity but not stopped entirely. My main box still craches occasionally (can't change channels or access home menu until forced reboot), and the errors on this thread still happen to mini boxes but now infrequently.
I had a bad experience with a Sagemcom recorder box many years ago, lots of crashes and errors. These EE boxes feel the same poor quality. I will be going elsewhere when my contract ends next year and be recommending friends and family against EETV.
30-09-2025 09:27 PM
Having moved to EE about 2 months ago, in the last two weeks I have started to get the YVM102 error every day. I need to reboot the router and my EE TV Pro box before I can watch. The system then works fine until overnight. When it seems to fail again.
I’m using a WiFi signal but have a good signal and no other devices in the room have a problem.
Not impressed.
01-10-2025 04:01 PM
Good afternoon @Mikedevs.
Welcome to the EE Community!
If possible, can you try using a wired connection to your EE TV box, and see if this gives the same connections?
As others on this thread have mentioned, Powerlines can be a good alternative if the wireless signal isn't providing a stable connection.
Peter
01-10-2025 05:34 PM
02-10-2025 09:04 AM
Thanks for this observation @Mikedevs
Please keep up updated with how you get on once the Deep Sleep option has been turned off
Ali
13-11-2025 10:22 AM
Hello , I have just received a new EE pro TV box after previously having a BT 4K TV box .I have had the new box for approx 1 week.
The box is hard wired to my BT hub
I switch the box off every evening when finished viewing . The next morning the box will not connect to the BT hub.If I unplug the ethernet cable for 10 seconds and then reconnect the connection returns and all is ok until the box is off for a period of time .
Is there a solution to this issue .
thank you.
