code Yvm102
Lee14801
Is just me but every time I turn on my pro box I get code Yvm102 or 105
53 REPLIES 53
Leanne_T
Hi there @dogwalker4
If you reboot the TV Box does the error code show again? Have you reported this to our broadband tech guides?
Thanks.
I am constantly rebooting my mini boxes. The errors does not show again
immediately but will sometimes come back in the same viewing sessions,
often there again next time the box is turned on. Happens in two mini
boxes, both with very strong wifi signals (one of them has an EE extender 3
metres in front of it with 200MBit broadband(.
Before rebooting i always check wifi signal at the box, always strong. My
TVs smart functions are always still working fine, just these error prone
EE boxes.
Hi Leanne
when rebooting box code dis sappers but what I have found that after watching chancel 5 it reappear and i have to then reboot once again.  have reported this issue a few times now and keep getting different things to try but still getting it.  EE have recently sent me a pair of powerline links as my hub is upstairs and smart TV  downstairs these new ones I cannot get to configure with my hub so at the moment have averted back to my old BT Mini Connectors to see if the sorts the problem out.
Nigel
Hi Dan
I have 700Mb and still get the code as I have said just changed back to my old BT MinI connectors to see if this solves the problem, what i don't get is EE know about this problem but still can't find a fix didn't have this problem with BT and I pay over £90 a month for this service
Leanne_T
Hi there @dogwalker4 @Den543
Do you get the same error code YVM102 or is this different?
Have you both been in touch with our broadband technical support guides?
dogwalker4
Yes I have twice in the last couple of days, gave me different things to try,  tried them still no change as yet waiting until tomorrow to see if my old mini connectors have solved my issue
Nigel
Leanne_T
Please pop back and let us know it goes @dogwalker4
will let you know if the bt mini connectors have solved my problem tomorrow fingers crossed
Nigel
Hi
Have spoken to guide at EE, was very helpful about getting code yvm102,  he checked my system and found that the power from Ethernet cable from hub to powerlink wasn't strong enough, after hooking my extender to my TV box  it appeared to work better but slow in start up. Has ordered me another extender to put nearer the hub hence making the signal to the TV box strong.  Will pop back when I've set it up with results
Nigel
Lesley_W
Thanks for popping back with an update @dogwalker4
I'm pleased they are sending you something to try and hopefully this sorts it, but please do let us know.
Lesley
