TV BOX PRO
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
25-05-2024 04:46 PM
I've just connected my new ee tv box pro. The aerial out cable I used for my old bt box doesn't fit the aerial out socket on my ee box so I have to always switch on my ee box to watch normal tv. Has anyone found an aerial cable that fits the ee tv box pro?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-09-2024 04:30 PM
I have exactly the same problem WM04 when upgrading from a BT TV box (that is now out of date) to new EE TV. As the aerial out is now a flushed port this is not as simple as suggest above. Please can you recommend a specific female connector or let me know how I can get new coaxial cable sent out Thanks.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-09-2024 07:07 PM
You need one of these at an appropriate length @ABL-1968 : Coaxial aerial cable
Other retailers are available, you need to ensure you get the right length to reach from the box to your TV.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-09-2024 07:38 PM - edited 30-09-2024 07:39 PM
EE, and before them BT, have never supplied this cable; it’s always been a user-sourced option.
My existing cable fit perfectly, though I can see how a bulky one might go over the earlier protruding sockets, and not go into the new flush ones.
Screwfix have a good option at £2.39; it’s a male-male cable with a female-female adapter, allowing it to function as either of the cables a YouView or Pro box might need, and is as slim as it can possibly be.
- « Previous
- 1
- 2
- Next »
- Did not receive 24 month Xbox ultimate and £70 EE Game Card with Xbox Series X in Gaming
- Moving soon and EE does not show on my postcode. in Broadband & Landline
- How do I block numbers to my landline phone? in Broadband & Landline
- No broadband after power cut in Broadband & Landline
- Scam calls in Security
