25-05-2024 04:46 PM
I've just connected my new ee tv box pro. The aerial out cable I used for my old bt box doesn't fit the aerial out socket on my ee box so I have to always switch on my ee box to watch normal tv. Has anyone found an aerial cable that fits the ee tv box pro?
25-05-2024 05:18 PM
@WM04 The socket on the pro box is a standard TV aerial coax plug.
You might want one of these
And this is a
But without seeing what you’ve already got this is a guess.
25-05-2024 08:35 PM
Thanks for your reply. I do have 2 aerial out cables (both could connect to my old bt box) but neither fit into the new ee tv box pro.
25-05-2024 10:27 PM
This is the cable I used for my bt box (one end into my tv, other end into bt box) However, it doesn't fit into my new ee box
26-05-2024 05:00 PM
The Pro Box does have recessed aerial ports so they don’t stick out as much as they do on other devices where your cable would fit OK.
You will need to buy an adapter or another aerial cable with less ‘sheath’ over the female end.
26-05-2024 05:59 PM - edited 26-05-2024 06:03 PM
@WM04 Here’s a better picture of the port on the pro box and the image below is the coax plug that goes in it. This a coax male plug and this is the plug on the right of your image is.
the connector of the left of your image is a coax female.
You can purchase a new plug male/female and just cut off the connector you have and fit the new plug on the cable. It’s really easy to do. Have a look at THIS
26-05-2024 06:24 PM
@Chris_B wrote:Here’s a better picture of the port on the pro box…
27-05-2024 03:30 PM
Thanks for your help. I actually contacted ee yesterday and the helpful guy is going to send me an aerial out cable. Hopefully this should solve my problem but if not, I'll buy a connector as you suggest.
27-05-2024 03:47 PM
As I understand it, a coax male plug goes into the aerial in socket on the pro box so I need a coax female plug for the aerial out socket on the pro box. Do you have a link for a coax female plug that I could purchase anywhere?
27-05-2024 03:54 PM - edited 27-05-2024 03:54 PM
As you've said yourself, you're being sent a lead by EE. No need to buy anything.
Your existing cable has fitted connectors on, so it's not suitable for replacing just the plug - you'd want to buy a new coaxial cable. Any good DIY or electronics store would sell them for less than £5, usually with a male connector on each end and then a coupler with it - this converts one male into a female, allowing all the normal combinations of cable you'd need.
