My EE remote
Briman
My remote has been playing up and is now unresponsive when you press the buttons channel change volume etc
Peter_W
Hey @Briman.
Welcome to the EE Community!
Whilst it's going to sound really simple, have you checked to make sure that the batteries aren't on the way out?
It's also worth trying to re-pair the remote using the instructions you can see here:
Reset Your EE TV Remote Control | TV and Sport Help | EE
If these steps don't work, I'd definitely recommend giving our team a call like @Chris_B mentioned 😊
Peter
@Briman then you need to call customer support and inform them of this  so a replacement remote can be sent out to you
Peter_W
Hey @Briman.
Peter
