on 29-10-2025 12:41 PM
Box:
Manufacturer: Sagemcom
Model: RTIW387
Variant: RTIW387.002.P
Hardware Version: 0007
Software:
Component Software: 4.2.226(6eac6b)
Manufacturer Software: 0.14.56
Broadband connection is wired.
My eetv box keeps losing channels overnight, even after factory reset. Initially, I had 175 channels. All seem to be 100% signal quality, an example being channels 102.
Each morning, I have either 74 or 26 channels left. Channel 102 is one of those missing. If I retune or factory reset, the channels return. They seem to be lost again overnight. All cables seem to be connected correctly and given the channels always show as 100% without fiddling with these, it seems to be a box issue. I am not sure how to proceed.
on 29-10-2025 12:47 PM
Is anything being turned off overnight that could be affecting the aerial? e.g. a signal booster? Or is the aerial passing through any equipment on its way to your TV Box, that is being turned off?
Also, it's worth checking signal strength - if this is also 100%, then the signal is actually too STRONG for the box. An attenuator would fix this.
on 01-11-2025 02:00 PM
The aerial line is directly in the ee box before being chained to other devices. The loss odmf channels is now even more regular. Can lose channels within the same day. In fact, any time I come back to pressing the power button to activate the software, numerous channels have been lost. Went down to 24 channels today.
When remaining channels are tested for signal quality after the channels have been lost, it is very low and sometimes becomes undefined with no picture broadcast.
Again, if retuned, channels are around 100% quality/strength.
No changes have been made to the aerial.
on 10-11-2025 05:22 PM
Hi there @Stainl988
Thanks for posting on the community.
Have you been in touch with our technical support guides since you last posted on the community?
If not, please get in touch and they can help you get the EE TV box looked into for you.
on 02-12-2025 12:25 PM
How are things going with your TV Box Pro @Stainl988 ? Are you still seeing channels disappear? Did the helpdesk manage to fix it for you?
The reason I'm asking is that I'm trying to investigate this further, so it would be good to get more information from you.
