on 02-04-2025 10:56 AM
I’ve searched EE help and this community and can’t find a solution:
I’ve read that Freeview has rearranged some of their TV channels and wonder if EE can/will invoke an update to the TV boxes overnight, or do we have to go into setting and retune?
Thanks.
Solved! Go to Solution.
on 02-04-2025 03:02 PM
YouView are usually pretty good at tracking changes to the Freeview channels, in which case you need do nothing.
But they can be caught out by some adjustments; if you see duplicated, or apparently duplicated, channels in the 800 range, then you will need to do a retune.
on 03-04-2025 09:41 AM
Thank you.
