Fast forward through ads on recorded programme
PaulRP63
Can I fast forward through ads on recorded programmes on the ee tv pro box?
13 REPLIES 13
@PaulRP63   The simple answer is no.  It’s part of the agreement to broadcast that service via EE tv
graybag
I also have EE TV Box Pro with TV Aerial connected.I can fast forward through ALL Recordings made via Channels in Guide which for me are all Freeview and BIG SPORT Channels.I believe it is only if Channels are delivered by Internet Mode only that they cannot be fast-forwarded,Hope this helps.
      Graham
@Chris_B
You are assuming the OP is in IP Mode, where you would be correct, but even then I think only for ITV channels.
BBC iPlayer is pseudo-recorded in IP Mode, which brings issues of its own, but they don’t have adverts.
In Aerial Mode, no such limitations exist.
Jonty1964
I can fast forward in aerial mode but the problem is sometimes the fast forward panel stays on screen throughout the rest of the programme, therfore blocking a third of the screen
Peter_W
Hey there @Jonty1964 😊
Is it only when fast forwarding in aerial mode, following a pause / rewind that you encounter this error?
Have you had a chance to see if catch-up has the same issues?
If you haven't already I'd recommend trying a light reset on your EE TV box too.
Peter
Jonty1964
I am only in aerial mode and this happens most of the time.
I haven't checked on catch up but then I have never noticed a problem.
John
Peter_W
Thanks @Jonty1964, as a first port of call I'd definitely recommend this reset, then we can take a further look from there 😊
Peter
Jonty1964
Ok, I'll do a reset and see what happens,
Jonty1964
I did a factory reset and the same problem arises.
