10-03-2025 12:13 PM
Can I fast forward through ads on recorded programmes on the ee tv pro box?
05-06-2025 04:59 PM
Thanks for giving this a try for me @Jonty1964.
Was it the reset where you keep your recordings that you tried here, or did you fully wipe the box?
Have you noticed any difference between the channel being recorded, too?
Peter
05-06-2025 05:41 PM
I reset keeping the recordings. There is no difference in the recording of the programmes
05-06-2025 06:42 PM
Cheers @Jonty1964.
I've checked to see if we're aware of any similar reports to this, and I can't see anything logged, so my best recommendation here will be to give our TV Tech Team a call.
They'll be able to run a few additional checks here, and if needs be either investigate further, or look at replacement options.
Peter
26-11-2025 08:48 PM
If you are in internet mode. I have found a way if your watching it slightly behind. When it gets to an advert in your show press channel up then down quickly before the channel actually has time to change channel. Then press fast forward and there you go
