Re: Ee tv box remote
Uncle_Remus
Hi, I am trying to use an IR blaster to control the EE TV Box and need the IR codes to set this up. Please could you advise how I get hold of these. If the remote works when not connected via Bluetooth then I'm assuming its using IR and there must be a set of codes for this?
OK no problem.  I don't know the codes myself, but there appear to be a few results found in Google.  The codes for all YouView boxes are the same, so search for YouView rather than EE TV specifically
DarrenDev
EE Product Expert
Yes, the box supports IR. What IR Blaster are you using? One that relays IR from one place to another (e.g. to control the box in a different room)? Or one that you're trying to programme to send commands without using a remote?
Thanks for the swift reply. I'm using a Matrix switch that has IR controls built in but I need the codes to build the profile for the Matrix to use. To answer your question I do not want to use the EE control - rather an all in one software. Thanks
Thanks that worked at treat as You View was a known set of commands - thanks for the help
