Ee tv login password
Ranatahir_78
Hi which password we need to use for ee tv login
@Ranatahir_78  Do you have EE TV as part of your EE broadband ?
DarrenDev
EE Product Expert
If your broadband is with EE then you manage your EE account at ee.co.uk or in the EE app - the login you use for that is what you'd use for the EE TV app (making sure you select the "EE Broadband" option on the login screen).
If your broadband is with BT then you manage your BT account at bt.com/mybt or in the My BT app - the login you use for that is what you'd use for the EE TV app (making sure you select the "BT Broadband" option on the login screen).
